Originally Posted by SoftballJunnkie
So, I was about to do my first oil change from purchasing the car from Frank(Never Enough). Took into my buddies shop to get a routine oil change. He called me over and we went to look under the car and their was oil everywhere! I mean seeping down onto the skid plate, water pump, pulley's, etc. Most of it had been dried up from the heat, but lately I have been smelling burned oil and I thought it was from the water since its been raining non stop here. Anyways, he was telling me it looks like its the seal from the oil filter housing that it was tightening really tight.
I hit up Frank since he is more knowledgeable and said that if its the sealant ring changing the oil will fix it. He said the oil filter comes with all new seals and are pretty delicate and rip easy. I do drive the car hard at times, so I'm not sure if its because of that.
Anyways, the oil level is good we checked it. Just wondering if any of you SRT owners have had this issue? I'm going to bite the bullet and take it into Chrysler for a $120 oil change to make sure its done right and I guess make sure nothing else is wrong with the car.
TIA.
Purchase your oil and filter before going in @ Oreilley's (I believe it's $5 a quart) That way the oil change will only cost you about $20 or so.
Also many people have put the O'rings in the wrong spots when replacing the filter. This is possibly what happened to you. You can get the crush washers too if you're so inclined. 3 for $2 I think.
