Old Jul 19, 2005 | 12:46 AM
Steve in SoCal's Avatar
Steve in SoCal
Default Re: a cure for the annoying rattles? HELP
The problem you describe requires the replacement of the rivet holding the upper part of the trim piece attached to the rear quarter window with a screw and nut. The procedure is covered in TSB 23-001-05 issued 1/8/05. I just had mine done and it solved the problem completely!
Good luck.
