Old Jan 13, 2011 | 10:40 PM
dinasrt's Avatar
dinasrt
Default Re: Shuriken Light Weight Battery Kit
do you guys want the rubber spacer to be thicker? im all ears, ask and you shall receive
Well, given this opportunity... How about using that material you use and make it the dimension of the OEM Batt. to be placed on the base, and routed out w/ the CNC (can it do that?) to receive the Shuriken Batt. so it fits like a baby in the cradle. This is in addition to the piece you already supply for the top, because it helps spread the load out over the top. This would be quite clean and I'm guessing pass any battery integrity inspection.
