Thread: 19" & 20"
Old Jan 14, 2011 | 07:40 AM
maxcichon's Avatar
maxcichon
Default Re: 19" & 20"
I'm sorry. I've been running 19's and 20's for 2 years, but this topic has been beaten to death.
Search is your friend!
In a nutshell:
If you go 235 width or more in the front, you will have to add offset to avoid the upper ball
joint nut.
If you go 275 or more in the rear, add offset or it will rub at the top of the wheelwell to the inside.
Keep the same "rolling length" or diameter as OEM. Or as close as possible.
You will have a hard time finding exact matches for offset in aftermarket wheels for our cars.
Use this tool: Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
it is invaluable for seeing what will fit.
