Old Jan 14, 2011 | 09:28 PM
  #164 (permalink)
onehundred80
Default Re: HID Install Lows and Fogs with Pictures
Originally Posted by Togroovy
I've installed my HID's according to this thread and gone through almost everything I can think of, yet while the engine is running only one side (passenger) will fire until it has warmed up. If the engine is not running than both will fire correctly. Would anyone happen to know why this is? And for reference I am using a ddm 55w kit.
I'm only guessing but I would suspect the ballast is a bit touchy.
Is it possible that it gets a higher voltage/amperage when the engine is not running?
Maybe the battery is a bit low and can start the lights when the starter has not drained the battery a little too much and when the battery is charged up a bit more then the light get a good kick from the ballast.
If both the ballasts are not for 55 watts operation and one is for 35 watts that may cause a problem.
