Re: Rear suspension aligment
Did they check the toe which is adjustable? Toe changes does have a small effect on the camber. if your car isn't lowered you shouldn't have a camber problem. Many have lowered their cars without adding camber kits. My car was wearing the inside edges but it was caused buy being toed out. Are your rear tires also cupping on the inside edges which will cause noise from the rear tires? Some tires are just prone to do this.
