Old Jan 15, 2011 | 09:41 PM
32krazy!'s Avatar
32krazy!
Default Re: Shuriken Light Weight Battery Kit
this is prolly the setup he used. 2 qt tank in the kit
The Best Water injection system and water methanol injection systems at AlcoholInjectionSystems.com
how do you plan to remount the holdowns? cant see the underside. the neg looks to close to the holdown to get the neg cable back on in the second pic. im not sure why you had to cut the spacer, if it fits in the oem setting it should fit turned with a longer cable right?
