Old Jan 15, 2011 | 10:04 PM
oledoc2u
Default Re: Shuriken Light Weight Battery Kit
Originally Posted by 32krazy!
this is prolly the setup he used. 2 qt tank in the kit
The Best Water injection system and water methanol injection systems at AlcoholInjectionSystems.com
how do you plan to remount the holdowns? cant see the underside. the neg looks to close to the holdown to get the neg cable back on in the second pic. im not sure why you had to cut the spacer, if it fits in the oem setting it should fit turned with a longer cable right?
Now you are close to my set up...but haven't finished it yet...the wire type tie down flexes too much to hold the battery down tight...so, I used a piece of aluminum to hold them down...I am building a bottom plate to hold the pump, the meth tank, and the battery all in the old battery location....
