Old Jan 16, 2011 | 02:20 AM
dinasrt's Avatar
dinasrt
Default Re: Shuriken Light Weight Battery Kit
Originally Posted by 32krazy!
this is prolly the setup he used. 2 qt tank in the kit
The Best Water injection system and water methanol injection systems at AlcoholInjectionSystems.com
how do you plan to remount the holdowns? cant see the underside. the neg looks to close to the holdown to get the neg cable back on in the second pic. im not sure why you had to cut the spacer, if it fits in the oem setting it should fit turned with a longer cable right?
To answer your questions; 1.) SS 1/4" bolt & locknut, with a slight recess in the rubber floor at the bolt head locations. 2.) You would install cables before securing the top of hold down. 3.) There's a 1/4" difference in dimension that way. It was a very tight/snug fit to squeeze the hold down posts together and get the threaded rod through the hold down top. It was necessary to trim 1/4" as I mentioned before. It fits like a glove. 4.) IMHO, when I finish routing and installing the floor, this set up would pass the 6' ladder drop test. It might crack the batt. but it won't come out of the hold down. Meth tank is down the road for me, but look forward to seeing what Doc has going on.
