Re: Battery Acid Ate My Line!
Originally Posted by velociabstract
Pues, ya se arreglo.........oops, wrong forum. (pirate speak!) I fixed it. A little piece of rubber hose to connect the two pieces together and 10 minutes. Observations: the transmission seems to shift smoother driving calmly. The idle speed hardly moves, not that it fluctuated a lot before but now its rock solid. I tried to trace the hose without taking anything apart but couldn't. It comes from the cabin under the battery box, passes under the ECU box, between the heat shield and the firewall and then I can't see where it goes. The next time I remove the CAI I'll keep following it. But if it's broken there's a vacuum leak. So fix it.
Les
It goes to the left rear of the intake manifold. It is attached to a small rubber hose which is attached to a nipple on the intake manifold. Where it comes from is a mystery to me.
