Old Jan 18, 2011 | 09:18 AM
Coyote's Avatar
Coyote
Default Re: Srt-6 vs Infinity G37 S?
Originally Posted by jonnyb
Coyote - not sure where you are getting your info, but the 2008+G37 is rated at 330HP - not 225 as you stated in your post. That's why on paper you would think it might be a close race. However, take a look at the torque - the G37 has a paltry 270 Ft/Lbs compared to the SRT6's 310. That additional 40 ft/lbs makes a huge difference in a race!
Before the SRT6, I owned an 05 G35, which was only 298 HP and 258 torque (dynoed 254 HP, 226 torque at the wheels). I raced my same friend in the same type of race when he first got his 09 G37s, and while he ended up edging by me, the race was pretty darn close. Those infiniti's are only mid/high 13 second cars, and I doubt a cold air intake will give more than 5-10 HP, which isn't going to knock a half a second off to get it down the the SRT6's low 13 second capability.
Even if the exhaust mod slows down the SRT6 a tenth or two, I would wager that it will still win fairly easily. My buddy with the G37 refused to believe that my SRT6 was stock because I walked away from him so badly.
Jonnyb, I got my info from a quick web search. BTW, you mention the 2008 G37 S, but there was no reference in the original post to the year of the
particular G37 S. What I found was for the 2010 G37 S, and is quoted below from 'Top Speed" at topspeed.com.
"The 2010 Infiniti G37S is equipped with a 3.7 V6 engine that features an aluminum alloy block and heads with low friction coated pistons, double overhead camshaft (DOHC), and 4 valves per cylinder with micro finished camshafts. This setup allows the vehicle to produce up to 325 hp at 7,000rpm and 267 lbs. of torque at 5,200 rpm".
So, guess we really need to know what manufacturing year this particular
car was built.
Coyote
