Originally Posted by DFWSBR
Use the 50x4 outputs. You will only use the (+ and -) on the LEFT FRONT and RIGHT FRONT wires off of the harness. The rears should be taped off and not used. The crossfire operates off of 2 channels. Left and Right. It has a built in crossover that sends the right freq to the tweeters, mids, and subs.
The RCA connectors are designed to run a cable from the deck to an aftermarket amplifier. This would then require you to run you own speaker wire directly from the amp to the speakers on the vehicle. This of course would bypass the built in crossover / amplifier system. RCA's put out a lower voltage as they are used to send a signal to an amp, not power anything directly.
Hope this helps.
