Re: Removing front plastic on headlights
I actually used a black plumbers epoxy. Figured if it worked on pipes, it'll keep moisture out of the headlights. So far so good,(knock on wood) we've had no problems so far, but she's in storage at the moment, and Spring will be the true determining factor. Hope this helps. If you want more info, let me know, I'll answer as many questions as possible.
