Old Jan 20, 2011 | 10:11 AM
LantanaTX's Avatar
LantanaTX
Default Re: $4000 To Get Convertiable To Go Up And Down Again
I just tried to call you. Testing the micro switch would be a very good idea. Also check fuses. If it is the pump. Go on Ebay and do a search for "Crossfire Spoiler". You will see someone selling a rear wing for a convertible. I would send him a message and see if he has the pump and if so what does he want for it. If you Crossfire is out of warranty I wouldn't go near a dealer EVER. Find a good local mechanic that works on Mercedes. Some of these guys don't know the Crossfire is a Mercedes, so if he tells you he doesn't work on Crossfires, open the hood for him and ask him if he works on SLK320's. Independant shops typically have a cloned version of the MB Star diagnostic System (DAS) which can do a lot on a Crossfire but not everything. they would need a DRBIII with the Crossfire card to do everything. Many mechanical problems can be diagnosed without the use of a diagnostic system. Hope this helps. $4,000 is way too much to pay.
