Old Jan 20, 2011 | 01:28 PM
magredvet's Avatar
magredvet
Default Re: $4000 To Get Convertiable To Go Up And Down Again
Mine did the same, and was fixed under warranty, turns out it was the top operating switch. Worth a try before condemming the pump. There is also a microswitch somewhere in the top framing, that senses that you have opened the header latch, and the front of the top is open. There was a TSB on this switch, as often it needed adjustment .....if I remember correctly.....maybe worth checking ..........
