Old Jan 21, 2011 | 07:29 PM
onehundred80
Default Re: Engine won't crank
Originally Posted by MurderedXF
i work at advance auto parts and we see it all, if your in a location where it is extremely cold and the car hasent been started in a few days or even over night the fluid, acid or distilled water can sometimes freeze.. check to see if it is still liquid... either that or it is just draineddddddd
From what I have heard and I checked again a fully charged battery will not freeze.
Also; From http://www.progressivedyn.com/battery_basics.html
If your battery is partially discharged, the electrolyte in a lead acid battery may freeze. At a 40% state of charge, electrolyte will freeze if the temperature drops to approximately -16 degrees F. When a battery is fully charged the electrolyte will not freeze until the temperature drops to approximately -92 degrees F.
