P1010143.JPG Finally got around to getting the rubber floor project done. I need to tell you that rubber was never meant to be routered!(I kind of knew that though) Smoke was in the air, the smell of burning rubber thick. After doing the first one, I just had to figure a better way, so I put the second one in the freezer hoping to get a little more working time. It helped a lot, but still a bit of smoke. The new space is intended for meth tank and pump, but this is down the road a ways. Oh, the stock batt. cable worked just fine. Had to bend the neg. side eyelet (that bolts to chassis) flat and the length couldn't have worked out any nicer. I recommend heating it up w/ torch before bending it flat so it doesn't crack from fatigue. I also cut down about half the height of the ground cable accessory ground stud for better clearance from the hold down top.
