Old Jan 24, 2011 | 04:14 PM
Goldwing's Avatar
Goldwing
Default Re: Radio static when i turn headlights on
If you have stock headlights and the radio only acts up when you turn on the headlights, then something is causing electrical interference. In the good old days, a static suppression gizmo could be placed on the coil wire to eliminate the problem, but there are six coils on these babies and no wires. You might want to try an store that installs custom auto sound systems (not a big box store) and they may have a suggestion. My guess is that replacing the stock radio may not eliminate the problem if something is causing electical interference. I assume with the engine off and radio on, it is perfectly clear? That's not a radio issue.
