Old Jan 26, 2011 | 01:11 PM
TerryR's Avatar
TerryR
Default Re: Question for My Texas Friends
Originally Posted by Marine05
Thanks everyone. When I got home from work I was able to get into the car and get it started. WD40 works wonders. Once I got into the car, I was able to pop the hood and saw that the negative terminal was not tight and could not be tightened any more due to corrosion. Next step... buy a new clamp/cable.
Glen,
I searched everywhere to try and find a New Negative Battery Cable to fit the Crossfire. Needed one 9" long (OR 230mm in English). Shortest I could find was 12" (305mm), but these were thicker in diameter, and too rigid to be fitted to the Crossfire. I ended up cutting the terminal end off the existing, and fitting a new end connection.
