Old Jan 28, 2011 | 01:01 PM
  #54 (permalink)
dinasrt's Avatar
dinasrt
Default Re: Shuriken Light Weight Battery Kit
Originally Posted by syfi
I simply used a nylon battery strap similar to the ones used to wrap around marine battery housings on my Odyssey PC680MJ, which is close to the same size, weight and shape as the Shuriken. Driven daily for over a year and hasn't moved at all. Odyssey also makes a variety of hold-downs and brackets that might give you some different ideas.
Odyssey Battery hold downs and accessories
Nice stuff, but our custom molded pad is a direct O.E.M. fit (with the center mount style). Just toss the pad in the batt.tray and bolt down w/ the O.E.M. hold down. And the molded rubber floor holds the batt. like a baby in the cradle. No rattle, and is more of a bullet proof application for those that drag or autocross. Their metal box is cool but probably not padded, and you'd need a flat wall to bolt it to, and it's kind of expensive for a tiny little shell. Just sayin'.
