Old Jan 29, 2011 | 03:18 AM
XFire-GTO's Avatar
XFire-GTO
Default Re: heated seats, seats or module
Originally Posted by 2005 Ragtop
Brian,
Pictured are the contents of P/N 68000519AB. It's good for the repair of 1 seat (back and bottom). No module included. The module I'm told is part of the ganged switch assembly that contains the heated seat switch controls and Hazard Flasher swich. Can ANYONE who's had the Switch, Heated Seat module replaced confirm that this (from the 2006 parts manual Figure 8-805, Item 1) is the correct p/n: 05097522AA.
V/R
2005 Ragtop
"The repair kit is good for 1 seat (back and bottom)"
1. In the pic only see 1 Pad for P/N 6800519AB... approx. cost is?
2. Are there separate Pads for the back and bottom, or 1 Pad controls both areas?
3. Besides heat to the back and bottom area.... are there any other areas that receives direct heat that need to be checked?
4. If one feels a good amount of back heat, should that same level of heat be felt on the bottom?
5. Would this be the correct P/N 05097522AA for the Module? if so, approx. cost.
6.. Does the Module control both both Heat and Hazard Flasher, or is there a separate module for both?
7. If the module controls both, and the Hazard Flasher work.... can it be assumed the module is not the issue relevant to heating the seats?
