Old Jan 31, 2011 | 05:12 AM
crossfirefun's Avatar
crossfirefun
Default Re: Found The Problem (cut Hydraulic Line) Top Won't Work
When using compression fittings on plastic you have to make sure and use inserts that go into the line to keep it from crushing. These fittings are used in the trucking industry for the air brake lines. Just an FYI so you dont crush the line to small or have it come apart.
