Thread: Replacement Key
Old Jan 31, 2011 | 06:57 AM
XFire-GTO's Avatar
XFire-GTO
Default Replacement Key
Recently bought a 2005 XF Coupe..... without rehashing all that went on during and after purchase.... 2nd Key was needed
Left=New Key.....Right=Key with XF
Chrysler dealer - Parts Dept:
01/26/2011 Wed.....Key ordered ($167.15).... comes from TX
A couple of hours earlier... Sales Mgr told me a new Key was approx $270.00
01/28/2011 Fri........Key arrived.... later at the Parts Dept:
Asked if it had to be programmed.... No, it comes programmed, just plug & play
The Lock/Unlocked/Panic buttons didn't work.... the Key itself opened the door/started iot right up.
Informed them of the situation..... no one in parts had a clue.... one fellow called TX.... told the Key must be bad.... will send another..... they even looked in various files for info on the Key.... nothing........ asked a few Service Tech, but anyone familar with the XF was not available..... left the Key.
Here is the kicker
10/29/2011 Sat
5:00 am.... looking through this forum for info on the Key issue and found the following link:
https://www.crossfireforum.org/forum...tml#post146279
Well how about that..... and no one Friday had any clue.
10:00 am... arrived and requested the Key.... told them I had a possible solution........ 2 minutes later.... told them problem solved.... one fellow asked how was it resolved..... let him read the printout I had from the link above..... he asked if he could photo copy it.... OK, no problem.
Thank you "ShawnKey" for that info..... appears I saved $100.00.
