Thread: Amp Issue
Old Jan 31, 2011 | 01:22 PM
BoilerUpXFire
Default Re: Amp Issue
Amp is located under the passenger floor area, the carpet is easy to pull up to access it, if you start from the furthest up under the glove box, it will peel right back.
Not sure about fuses, and if you do need to replace it, ask around here for a used one first, because some one else recently posted they want over $1500 for that OEM amp and it isn't worth 10% of that IMO
