Old Jan 31, 2011 | 09:23 PM
32krazy!'s Avatar
32krazy!
Default Re: Code 3 Pulley Installed
Originally Posted by mjgroves
I had to take mine off because I'm waiting to get my bearing replaced and it's definitely the most significant mod in my opinion. The NW dual was meh, and I already had a tune. But when you put on that pulley, you can really feel the torque increase.
It was amazing how long I had to search to find a C3 install guide on the forum, but I found it under the documentation collection.
I also had to take off the weather strip for the NW dual install and noticed that the hood is a lot rougher on the ears when closed and there's a bit of give when you pull up on it when closed.
Glad you like it!
mjgroves heres a quick way to get the bad bearing out. remove the c clip. knock out the old bearing with hammer and rod. stick the pulley in the oven at 250* for 10 minutes and the bearing in the freezer for 10 minutes. the bearing will drop right in!! reinstall c clip and your done!
