Old Feb 3, 2011 | 11:51 AM
BrianBrave's Avatar
BrianBrave
<--- Huge Horsepower
Default Re: auxilary input jack
Great job and I have to ask a question of you. Can I change the face plate from my non Nav Becker to my Nav Becker. Presumably the answer is yes. My non Nav faceplate is unmarked and the other has a few scratches. I'm assuming the black blank plug can be removed and have the button replace it.
I looked and after being told it was a risky operation I dropped the idea.
Yes, with a little patience you can "swap" the plastic covers, the ***** and buttons between the radios.
You can't swap the display or the electronics as they are different and model specific.
I have the 2660 CD changer and would like to add the phone option to the system eventually, that can be done according to the write ups but I did not find any parts to enable it to be done.
No - you need a complete new radio model for that, which means you will loose Nav but gain the other functions.
How do you get the face plate off?
So do the write up and let us all learn from your endeavors - please.
Remove the radio from the car. Remove the top cover - it just slides up.
You will see two small torqs screws. Remove them and the rest is all plastic clips (bottom and sides). Just be careful and patient and don't damage the display or electronics.
Good Luck.
