Old Feb 8, 2011 | 11:27 AM
onehundred80
Default Re: engine stopped while driving, would not start
Originally Posted by juzmerob
Wow, interesting. All I can say is, see what happens next. Like you, I would think that if it were the crank sensor it would happen all the time since the sensor affects timing. Seems like if it were the sensor you would have rpm issues. You might ask the mechanic about that. I wish I could give you a good answer. Keep us informed.
The failing CPS appears to be affected by heat, it often quits when it gets hot and will work again when it cools.
I have wondered that if you have one that is a problem if it would be possible to keep the temperature down if you wrapped some of that fiber glass/aluminum insulation around it. It sits in the tunnel and hot air rushes by it, it is screwed into the housing so maybe it gets a lot of heat from the block, who knows. It has a shield in front of it but it does diddly.
Electronic items do not like heat so keeping these CPS's cool should be a good idea.
How about a cold air intake ducting cooling air over it, you read it here first remember.
Keep a spare one and the tools to replace it in the trunk.
