This is what it looks like, of course the connector on the bulb is not there for you.
The spring ends goe into those hinge points, I have found that if you put your finger over the hinge points and you feed the spring end under your finger you can feel it go into the hole. I found that worked better than stabbing around blindly .
This picture is the best one I've seen that shows how it looks.
