Old Feb 9, 2011 | 11:27 AM
goodgenes79's Avatar
goodgenes79
Default Re: P0120 Code... need help
i also get that code the last couple of times I "reset" my throttle position. I just unplugged the battery, made sure everything was as it should be, Valve covers I'm looking at you. When I plugged battery back up everything works fine. Mine could be a failing TPS, and I am just buying time. It just seems that when I try to reset it through the peddle position, it goes bad. Cheers and GL
