Old Feb 9, 2011 | 03:43 PM
JHM2K's Avatar
JHM2K
Default Re: wheels education
Originally Posted by Jesus_Christler
I think not in the rear The thread mentioned 22mm offset with 9 inch rears.
Another thing with 19 inch fronts you would have to use a lower profile (height) than standard. Makes a difference in handling... not so good.
Rob (Needswings) is running the Lorinser replica on his car with no spacers and it's a 9.5" wheel with +35mm offset. Like I mentioned in an earlier post, it basically comes out to be a 6mm movement inboard.
Running a 10mm spacer in the rear would not only give you the same/more room than stock for suspension, but it would also simply look better, as it would widen the stance a bit.
