Old Feb 12, 2011 | 12:04 AM
ZAHANMA's Avatar
ZAHANMA
Default Re: SRT Maintainance after purchase
Originally Posted by cubanbee
I replaced the water pump and the i/c pump again still same problems
I would say replace your ambient temp sensor. If it is telling your engine that it is really cold (-36) outside, then your engine will be dumping fuel to try and maintain temperature....causing it to run hot and cut off the supercharger. It is a $12 part that you can replace your self, just plug and play on the driver's side lower louvre (lower grille).
