Old Feb 12, 2011 | 05:02 PM
onehundred80
Default Re: Trunk Panel Separation
Originally Posted by smokey847
I don't believe so. The separation seems to have stemmed from the bulkhead area instead of the side. It looks like the panel covering the gas tank has been pushed in and I don't know how to reshape it, nor remove it.
OK, I see that light colored area to the right of the gap, that is a dent?
If it is a dent then you will have to take out the side panel, this is a pain as to remove it you have to release at least half of the rear panel behind the license plate. That enables the side panel to slide out from behind the rear panel, once that's out you will be able to pull the dented panel into shape.
