Originally Posted by Epyon
i read that SAE changed the way HP was counted, under the new system i saw that the STS-V got more horses counted, and the Acura TL dropped from like 270 to 250.
question is, what will be the new HP rating for the Crossfire?
How can you change HP counting?
HP is an old unit for engine output. It is defined as the power of 75 kilopond meter within 1 second -> 1HP = 75 kp*m/s
Since the SI units the engine output is counted in W (watt). 1W = 1 J/s = 1 Nm/s.
By doing some conversion of the old units to SI the result is 1HP = 0.7355kW or 1kW = 1.3596HP
All car specifications show nowerdays both HP an kW. HP is still in use because the number is higher and looks better.
The Crossfire does 160kW equals 218HP. Now, what does sound better?
