Old Feb 15, 2011 | 08:37 AM
BoilerUpXFire
Default Re: fog light question
Originally Posted by West Peterson
??? I'm not following you. How do you separate the the glass from the housing?
Then clearly you have not attempted this. When you remove the assembly from the front bumper (easy access through the foglight door) and I think there are 3-4 screws holding it on. Once removed, you will see another 3-4 screws holding the lens on the assembly, remove these and you are there. This is really very basic, don't psych yourself out, just go out and do it....
A tip, if you angle the wheels the right direction for each side, you have lots more room to work with in the wheel well.
