Re: Crankshaft position sensor
Jesus 180, do you read any of the other posts around yours or what??
If I answer a post but the post I am answering is edited while I'm typing then I may be a bit wrong in my post. I did not go back to check the post.
The note about the code being still there was added while I typed. As was your note on clearing the code.
If you are so smart you could figure it out.
From this post on Feb 5th I assumed the car ran for a few seconds but evidently not.
Originally Posted by Holycrap
I have triple checked everything. Since eurocharged does not provide instructions a fellow memember sent me the let pulley instructions which helped a lot. But im sure there are some differences. Timing seems to be off. It cranks up hesitates, and dies down. what should i be looking for???? Thanks
