Old Feb 17, 2011 | 05:05 PM
onehundred80
Default Re: Interior lights/gauges blinking
On the way into work the last 2 days, I have experienced everything on the dash blinking 2-3 times and then going back to normal. It is very strange in that there are no adverse affects, just everything blinks several times, and the ALL the gauges zero out, then back to normal. When it happened the first day, I thought it was wierd, but wrote it off, when it happened at nearly the same time the next morning, I knew something was up.
04 NA coupe with a new battery
Thanks!
Simple explanation would be fuse #37 loose or an ignition switch problem possibly connected to fuse #35.
I cannot see a relay in the circuit which could cause the power loss momentarily.
