Old Feb 17, 2011 | 07:27 PM
  #45 (permalink)
Holycrap's Avatar
Holycrap
Default Re: Crankshaft position sensor
Alright i tested the battery and its fine. i have yet to test the cps wires since i dont know how.
In a last attempt to get a resolution before i get a professional involved i will mention anything that i think might help
-When i have the car on the on position i hear a buzzing electrical sound from the engine and i have heard this before and it sounds normal, however after a few seconds i hear a couple of loud clicks coming from underneath the throttle body.(it seems likes its coming from there)
-The car is on jackstands on the front end only
-My neighbor suggested to use locktite on the crankshaft bolt so i did.
-the fan is currently unplugged so i can have easier access to the pulleys
-i have yet to check any fuses.
-i used the stock belt as the instructions stated
- should i buy another cps just in case????
-my neighbot tightened the crankshaft bolt while i pinned the flywheel. if the bolt is too tight would this cause a problem with the cps?
-FML
Thanks again for everyones help!
