Re: Oil Leak or Faulty Oil Level Sensor
You need to look at the oil filter housing, with the engine running, and see if there is an oil leak there. That is the most common location for oil leaks right after an oil change.
You also need to look at the belly pan under the engine to see if that is where all your missing oil is going to.
Stop driving your car, and look for the leak.
BC.
