Old Feb 19, 2011 | 06:19 PM
mjgroves's Avatar
mjgroves
Default Re: How to remove tensioner pulley for PSK install?
Originally Posted by 32krazy!
let me advise you to install the belt BEFORE tightening the new bracket and bushings. once the braket is mounted you wont be able to get the belt on and have to remove everything to install the belt. install the lower new pulley, belt (just hang it on the pulley) then the upper pulley and braket. you will thank me later!
Thank you good sir! Will keep this in mind as I continue the install
