Re: opinion on which rotor to order
Its really what you desire...if your feeling like that now it won't change a bit if your only changing the front. I would advise you to do all 4 and get it over with...As for the your braking needs and wants.... Look up Centric brakes....they are the leader and formost experts in this industry. Keep in mind if the company your ordering your brakes from is giving a lifetime warranty on a rotor and pad, know that the the brakes your being supplied with are basically a lifetime working POS! So I would not walk away from those type of brakes I WOULD RUN! Before spending your money make sure you do all of your research...most of all take your time!
Good luck with your find
Originally Posted by tashspop
well i just ordered the eur ceramic premium pads with sensors
i'm getting suggestions about using oem style rotors on the rear unstead of slotted or drilled. would this not cause a little unballanced feel? i already feel like my car favors the front too much when breaking hard and i don't want it to get any worse.
