Re: need New Trany?!?! HELP
dis connect batt ,and drain elect. systen by opening the door 3 to 5 times with the batt disconnected,, then connect batt. and if the car drives normal for the first block or so ,,make sure you get into 3 gear if you do the tranny is ok it would then be the sensors jim
