Originally Posted by simmie777
It's worth knowing you can shut the alarm up by removing the # 9 fuse, however you will not be able to lock the car remotely and you will have no interior light.
Hope this helps.
Cheers,
Michael
I was reading up on alarm issues a while back, and I thought I read that even if you disconnect the battery lead, the Alarm will still sound as it had an internal battery (for security purposes).
I'm assuming Fuse #9 will disable the Alarm System, but the alarm has the potential to make noise till it's internal power dies.
Is this correct, or am I off base...???
