Re: killer chiller copy
that is funny, i posted up about that a couple of years ago here and it was immediately discounted so i just laughed and went on. around the same time i mentioned that hankook tires were a great bargain and no one was interested, how to custom design and have built a heat exchanger for a low cost along with photos of the one i designed with no one being interested, created a meth mixing calculator and uploaded it on my server, no one was interested, posted up detailed information on my meth datalogs, a/f ratios, timing, fuel trims, dyno graphs etc and so on. the killer chiller is a cool setup (pun intended) but there are other options as well. my stock heat exchanger is working sufficiently for my setup though.
it is an expensive setup, you could probably build your own for a lot less but unless you are doing extended high speed runs or hot lap drag race i would just toss a bag of ice on your supercharger for about 15 minutes before each run (if you drag race). it might be nice on the roadcourse or use a simple meth setup for cheap with a small nozzle so you do not increase a/f temps too much.
