Old Feb 24, 2011 | 06:07 AM
TerryR's Avatar
TerryR
Default Re: How to take apart a key fob without destroying it!
Originally Posted by tom2112
How to take apart a Crossfire key fob,
without destroying it,
or making it look like your dog chewed it up:
First, it’s a good idea to know a few facts about the Crossfire key fob.
  1. The fob is a transmitter, transponder, and physical key, all wrapped up in one.
  2. The transmitter is used to lock/unlock the doors/trunk of the car remotely. It can also be used to set off the “panic” mode of the car.
  3. A NEW fob’s transmitter can easily be programmed to work with your car.
  4. A USED fob’s transmitter from another car can NOT be programmed to work with your car. (at least, I can’t get it to work)
  5. When you put your key into the ignition, the fob’s transponder responds to your car’s ignition and replies with a special code, keeping your ignition’s kill switch from activating. (In other words, it allows you to start your car!)
  6. Any fob’s transponder can NOT be reprogrammed to work with your car. (That is, not without VERY expensive equipment, rumored to be possessed by some dealerships. See PDF attached below.)
  7. A transponder chip from YOUR car’s fob can be transplanted into another fob, and that fob will start your car, as long as you transplant your physical key along with it.
  8. The physical key can be removed from a fob and placed in another fob. The physical key will always turn your car’s ignition and door locks, but without the correct transponder, your car will not start.
  9. The ONLY fob that is guaranteed to work with your car is one that came with the car, and one that is ordered through your Chrysler dealer. New fobs cost about $130 – list price.
  10. Another type of key is available, called a “flat key”. A flat key will physically unlock your car’s doors and will also start your car. But it is not a remote. They list price for about $60 from your Chrysler dealer.
What does all of that mean? The BIGGEST thing it means is that buying fobs off of eBay is a waste of money unless: your fob was damaged, and you’d like to put a spiffy new plastic case on your fob. That is what this thread is about: how to transfer your old fob’s guts to a new fob.
To transfer the guts of your fob to a new one, you have to be able to open up your fob without breaking the circuit board inside, and the transponder chip inside. Also it is important that you not damage the “new” fob’s case, or your work will be for naught.
The first thing you’ll want to do is grab a knife or a screwdriver and pry the case apart. DON’T! That’s not very effective, and also tears up the plastic of your case, defeating the purpose of replacing it.
The key to getting the case open without mangling it is a nifty little tool, called a snap ring plier. The interesting thing about these pliers is that they have narrow tips and when squeezed, the “jaws” open, rather than close. You can get a set of these pliers at any hardware store. As of 03/07/08, Harbor Freight has them on sale for $1.99. See this link:
http://www.harborfreight.com/cpi/cta...temnumber=3316
This info for DTinker,
Dave found this post but not quite sure it is the one I remember. MAY be of some help to you.
TerryR
