Old Feb 26, 2011 | 05:54 PM
RMADERMAN's Avatar
RMADERMAN
Default Re: Weird engine noise! *Video inside*
My guess would be a bearing in the idler or tensioner. Or even one of the other bearings is highly possible.
I have had bearings that did that, noise and then nothing. If one finally seizes you'll need a new belt and a tow job.
Release the belt tension and spin the pulleys.
It's too dangerous to do the screwdriver to ear trick though.
I agree that is is a pully bearing. I went to have my belt changed and anf the pulley next to the supercharger was cracked all the way across and the bearing was making the same noise.
PS I had to call Rob at Needswins for a pulley saver kit due to the fact that the pulley is on back order.
