Old Mar 1, 2011 | 12:02 PM
freakingfastsrt6's Avatar
freakingfastsrt6
Default Re: opinion on which rotor to order
IMAG0346.jpg You must remove the little phillips screw out from the hub
IMAG0349.jpg you must remove the cap to get to the clip ring.. removing the cap on mine was hard cause it was siezed on, so I replaced them from mercedes $20 for the 2 after removal as you dont want any dirt getting into the splines of the hub...the remove clip ring with allen key
IMAG0351.jpg you must removed the hub from inside the rotor, should come out rather easy if not...take a mallet and from top to middle till it drops...or if your just going to throw away the rotor anyway go ahead and stand the rotor up and let it drop to the ground the vibration alone will let it fall out.
Originally Posted by tashspop
i tried and tried to beat the rotors off the car but i can't get them to budge. i did remove the retaining screw, they are just seized on. i think im going to have to take it to a shop and pay them to do it.
