what he said^^^ Actually it is a bit worse.....a $hitty Prius might be able to pass you when the IC pump goes out.
Easy fix, don't let the Dealership mess up your car of keep it for eternity (thereby increasing the likely hood of them denting or scratching it). Just buy an aftermarket pump and change it. It is very easy to do. There are some great "How To" articles on here posted up by members.
Good luck.
KrzyFast
Originally Posted by Coyote
It is really very simple to diagnose this problem. You step on the gas, and
instead of hearing the roar of the engine, and feeling your back pass through
your front, you get a sound similar to that of a plugged catalyitc converter
and the power of a prius.
No, there are no small signs. It just happens (based on experience x2).
Coyote
