I agree. I want this figured out before the summer months arrive. All I know is that if I turn my AC on my temp gauge goes all the way to Hot. If I leave it alone it stays fine.
What do u think?
Originally Posted by ZAHANMA
My first thought would be, did you check the coolant? If you are low on coolant due to a leak, or just a lack of a full fill from the last time, then that would be causing your temp issues. I would advise completely flushing, filling, and burping the coolant and see if that helps.
You may not be running too hot now, but it is still in the winter months and once summer comes you may have some more serious temps to deal with.
Also, if the dealer told you that the engine is running +400F from normal operating temperature...I might think about going to another dealer, because honestly. That isn't possible without making the engine go all sorts of not right.
