Originally Posted by 32krazy!
the end that is in your pic goes into the t/b. one side is plugged and the other goes to the catch can
question... did you remove your manis to install the new lines? if you did you will need new mani gaskets. the metal oem gaskets wont reseal so call rob and get 2 sets of the cork gaskets. 1 set for the reinstall and the other set for a spare. you will need them down the road for something
Yep he included the cork gaskets with the kit, so im all set on that regard.
Krazy, i know that portion goes into the tb, but im not sure of the orientation. Does the longer or shorter side of this piece go toward the front of the car?
Should i orient it toward or away from the butterfly valve?
Or doesnt it matter?
