Originally Posted by Crossfire725
Well is it the same diameter? Lol so will it fit. Mhm
I can't read the part number molded into the injector body, I would be able to tell you alot more with those numbers. You need a low impedance injector, which those should be but I can't tell you for sure. I dont know what the flow rate is on them either. You're wasting your money unless you are planning on doing other things involving a tune. The injectors wont open for long enough if they are too big.
